Rear Sway Bar
timcolr
Fort Wayne, Indiana
Does anyone have a rear sway bar they removed from a 2011-2016 F250 or F350, that mounts at the bottom shock brackets and also the links at the ends that attach to the frame. I would like to add one to mine, 2016 f350 2wd 6.7 psd.
Thanks
Tim
timcolr
Fort Wayne, Indiana
Yes, I have it's a 7715 Hellwig $360.84. Just thought if I could find one from someone who removed it because of a lift kit, I could put it to use and save a little cash.
timcolr
Fort Wayne, Indiana
I think the 05-10 mount to the top of the axle tubes on each side of the pumpkin and then the bar goes across the top of the pumpkin and forward to the links.
Diesel625
I’ll check out the one I took off my truck later. I think your right about the mounting points.
Sixfoh
I honestly thought they stopped doing factory rear sway bars on the 250 and 350. Both a friend with a 14 KR FX4 and my fathers 16 Lariat didnt come with them. Both 6.7 ccsb. Is it part of a different tow package or something?
timcolr
Fort Wayne, Indiana
The only way is to order the camper package, on a F250 it came with the overloads and rear sway bar, on F350 the sway bar, because they already have the overloads.
Diesel625
Checked the sway bar. It’s off an 06, and it mounts to the axle tube above the shock brackets.
