Recon cab lights
bens
Sorry if this is in the wrong section, and I did try to search.
I purchased some cablights for my 14 f350, it does not have them factory. Does anyone have the Ford part number for the harness that I will need? If so, are there different harnesses for different options, I have a sunroof, and power rear window. Not sure if that has its own harness or not. Anyone know if it will plug and play into the recon lights, or if I should use the harness they supply and tie it into the running lights somewhere.
Thanks,
Ben
Sent from my SM-G973U using Tapatalk
