Reese Trailer Hitch
03-Blue-Powerstroke
PA
The hitch on my truck is starting to get sloppy so I was thinking of upgrading to a Reese Titan class V 2-1/2" hitch. They are good to 18K with 2K of tounge weight. Has anyone tried one of these hitches or used a similar one? If not can you recommend another class V hitch? It looks like they cost around $300. Here is the one I have been considering...
http://www.etrailer.com/product.aspx?pc=45297&pg=Trailer-Hitch&manuf=Reese&45297
WeBeStrokin
Mifflinburg, PA
If you pull the loads I don't see why it wouldn't be a bad setup, I am looking to upgrade as well but mine does just fine cause I don't use the rear hitch that much anymore like I do the gooseneck. The other nice thing is you can get a shim to put in and still run the 2" receivers.
03-Blue-Powerstroke
PA
The most I will ever tow is around 14K. I was looking at that model because I couldn't find any available between 12 and 18K. I generally haul a tractor or firewood on a 14K trailer.
