Removal of tailgate emblem WITH camera
cmb921
youngstown, oh
I have a 2014 6.7 platinum. My rear ford emblem has the camera in it and I was looking to find out how to remove it so I can vinyl wrap it. Anyone know how this comes off? Some pages said just double sided tape but I'd assume it has to be more involved on the models that have the backup camra
Arconalloy
Warner Robins, GA
There is a small square on the bottom between the emblem and bezel I used a tiny flat head in the small slot and popped the bottom of the emblem up from the bezel then got my finger nails under it on each side and lifted off evenly. It's nothing but two plastic tabs that hold the emblem to the bezel then two hex head screws holding the bezel to the tailgate. The camera has a connector you can unplug and then just remove the screw holding the camera in the bezel once off the truck
Just make sure you pull the emblem off as evenly as possible or those plastic clips will break
