S366 egts??
06/6.0
easternshore of md
Anybody out there running a single S366 I'm just wondering what your egts are running at and what I should watch out for and what point in temps I should stop at thanks for the help guys :ford::lame2:
Powerstroke214
Baton Rouge, LA
I'm guessing yours is the truck in the vid Jamie sent? Looks/sounds good.
Injector size is gonna be a pretty big factor in temps. Kinda need to know that.
06/6.0
easternshore of md
So running 175/30s and thinking bout going bigger but don't want to if I don't have to what y'all think and wasn't running right today but did 440hp on a unloaded dyno
Powerstroke214
Baton Rouge, LA
I'd ditch the 366 and drop to a 362 or 364 FMW with injectors that sized.
I haven't followed the nonvgt crowd too much, but I believe the 366 is pretty much an entry level charger, Swinky ran his with 190/100s. If you're looking for hp, I'd probably run a 190 or 205 with a 366. If you're still towing, I believe a smaller charger and those injectors would be your best bet.
Six_Sloww
Southeast MI
.91 would be fine on the 364.5 make sure you get the sx-e, the turbine wheel is a little different and will help with spool up.
06/6.0
easternshore of md
I just talked to mpd and might just go with 190/100s to spool the 66 I got some thinking to do lol
JGman141
Ohio
Trust me you don't need/want 100% nozzles on 190s, a 75% nozzle can dump roughly 240cc. If you want to tow I'd look at 50% or even 30%
06/6.0
easternshore of md
Ok so last question hopefully before I make my desicion lol go back to vgt and run the barder stage 2 or s364.5 lol
04cr450
harford county, maryland
Depends.. do u like instant boost and the annoying azz whistle? Or do u want a real sounding diesel with somewhat but not to worry lag and a truck that pulls and pulls on top?
