S467.7 Borg Warner turbo
V-Ref
9 miles high @ 550 mph
S467.7 FMW Borg Warner turbo
$1000 shipped
Best price I could find on the net. Be sure to add shipping AND a turbine housing.
http://www.agpturbo.com/borg-warner-s400sx3-fmw-billet-67mm/
I think we've got a vendor or two that can probably get you one WITH a turbine housing for 1300+...and some shipping.
1.10 T4 divided turbine housing
20k miles
Mobil1 synthetics every 3k miles
Never over 10 psi until oil temp over 100F
Always ran with a Donaldson air filter
Turbo specs-
Turbine Housing=1.10 A/R T4 divided
Turbine Wheel= 83.5 inducer, 74mm exducer, Iconel 713
4" discharge (downpipe)
Compressor Wheel=67.7 mm inducer, 91mm exducer Forged Mill Wheel (compressor map below)
Race compressor cover (its huge; the attached pic shows the clearance using a TN mount and WOP plenums and the silicone boot for the compressor)
It's a 5.5" inlet, with a 3" outlet.
I can include a turbine housing blanket, a 5.5" to 4" 90 deg rubber boot for your intake tube, and a silicone boot that connects the compressor discharge outlet to hot pipe connection for the right deal. (All depicted in the start/idle video)
Compressor Map
What it looks like on the truck (pic & video)
What it spools like from a second gear roll in a smoke free "towing" Gearhead tune
http://autorotate.smugmug.com/Other/SuperDuty/15421552_mfrFhH#!i=2117321778&k=r3Ft26p&lb=1&s=A
What it spools like from a zero throttle coasting in 6th gear, and then rolling into a smoke free roll on with a Gearhead "towing" tune.
http://autorotate.smugmug.com/Other/SuperDuty/15421552_mfrFhH#!i=2117324865&k=wbsH7XL&lb=1&s=A
There's absolutely nothing wrong with the turbo. Only reason I'm selling, is I'm installing a different turbo.
I'm hesitant to even change the setup...this turbo is very responsive, and cleans up a lot of fuel.
For the $$$, I don't see how you can get a better turbo for the 7.3
