sector shaft nut size for 2002 F350
Gulfcoast
South Texas
Can somebody tell me the size of the nut on the sector shaft of the steering gear? I think I used a 34mm socket when I installed the steering gear but it was not a perfect fit. I think its coming loose and I want to get a big open end wrench to tighten it:doh:.
JLDickmon
Pitman shaft you mean?
Sector shaft is the one the steering column bolts to.
it shouldn't come loose.. it should have a bigass lockwasher on it.. unless you didn't get it down on the shaft good to begin with.. just rattle it on with an impact
Gulfcoast
South Texas
Sector shaft is what I was told it was called several years ago when it broke in half. Here is a diagram showing the part I am talking about. This diagram is for a gear for a F150 but the steering it is similar.
http://www.justanswer.com/ford/3d37a-93-f-150-steering-gear-box-play-it-can.html
Oh and the nut it is 1 5/16"
