Short bed dually conversion
Ed3196499
I am thinking about converting my short bed to a dually where can I find the bed sides for the short bed? I would really like to find the new style bed but either or is good .
Jason
Somewhere down in Texas..
I've had the same thought cross my mind a time or two. I think if you could get the 2011 style fenders (dunno if they would work or not) that a ccsb dually would look sick! Be real sharp on a set of 19.5's too....just sayin' ;)
TrailerHauler
Michigan
That'd be cool.
Find and purchase a shortbed dually, or buy the flares, drill the holes in your current bed and bolt them up. A rear axle, dually spacers for the front, tires and wheels and you'd be done.
MAC
Richmond, IN
Is using spacers, a "wrong" way to do this? I'd be all over it if I didn't have to swap out rear axles.
Using spacers isn't really the "wrong" way, but I think most people don't use spacers just for peace of mine.
Think about how f*cked you'd be if a spacer came loose while you were towing heavy.
TrailerHauler
Michigan
The fronts from the factory are just a spacer on a dana 60, or a wider hub on a 2wd.
fordfreak4life
no conversion here... factory built but should give you a good idea of what it could/will look like
TrailerHauler
Michigan
I was mainly talking about using spacers in the back.
Yeah, I agree if you want to do it right you'll swap axles.
But at the same time I wouldn't be to hesitant on running spacers, anyone with a dually with a tire wider than a 255 is running a spacer. Granted the spacers only holding up the outside tire there's still a lot of people running a spacer to clear wider tires.
