Show & Go/Going to Try this Out combo Build
Mesa, AZ
Hell i think this is just an excuse for more people to see your avatar pic. Thank you kind sir...:clapping:
Jonnydime
As some of you know I bought Dan's 08' Harley truck and after a 2,000 mile drive I have it here in Florida. For first part of this build I'm going to pretty much consolidate what stays on what truck and what gets sold. If you didn't know I already have a somewhat built 08' that will be for sale. This is just the beginning as I have an interesting plan involving an F3 procharger with an 88+mm precision and lots of fuel.
Harley Truck.------------------------------------------ Red Truck.
Fully built motor---------------------------------------Not built Motor
Rcd 60% injectors ------------------------------------Rcd 60% injectors
Rcd cp3 dual fueler------------------------------------Midwest twin k16 kit
Fass low pressure fuel---------------------------------My custom aeromotive setup
Full built Trans with Rcd converter-------------------Elite stg5 with 13"dpc Converter
Dan's Traction bars and leveling kit------------------Lowered with Pmf Traction Blocks
New Rcd 4 link in box---------------------------------Factory radius arms
22's and 35's------------------------------------------18's and 33's
First off I plan to keep the Harley truck the same height it already is maybe add a Carli 4.5" kit at sometime. I am going to ditch the 22" wheels that are on the truck and run my 18" weld dunes with some 35's
Harley under hood
Red truck under hood
Is the midwest duel fueler going to the new truck i hope?
Jonnydime
Absolutely
I forgot to mention turbos the Harley truck has a set of 75/59 Rcd work stocks and the red truck has my custom compounds with an 82mm Precision feeding a Garrett gt4088r.
Jonnydime
I'm in the Seminole/Largo area. The Harley truck has an AFE intercooler.
Jonnydime
I’m going to put the pmf bars on the Harley truck and put dan’s bars on the red truck. So technically dan’s set is for sale you just have to buy the red truck to get them.
Jonnydime
I don’t know how either of these happened but both happened to the Harley truck.
