Spring Adjustment-lift kit
bordo380
I'm posting for others struggling with their rough ride that after pulling a leaf out of my front Spring pack it rides a ton better.
These were 4" lift pro comp Springs. It had a small amount of flex. I could run with my shocks off and it didn't matter.
One area of concern is these springs are about 6 months old and look how warped they are.
I would return them but it kicked my butt putting them on. After I got them all back together minus this spring it's seems great. I was about an inch high in the front and I wanted my rake back. This brought the front back down just enough.
Before
After + 20" wheels
TARM
Personally I think I would have just used some X code for snow plow 250/350s for stock Ex springs that are likely sitting on the bump stops if they are there or lower they will add 3+ inchs. WHerer they should be they add a little more than half that.
The issue with the X is they wanted it to fit in all newer garages but they still wanted it to keep the 250 rating. Thus the front got really soft cheap springs and the rear got uch stiff but dearched springs to lower the hieght.
What you end up with is a rear will little flex and very stiff and front that is super mushy right till it ends up sitting on the bump stops 6 months after new.
Nicest leaf spring setup I have seen were V-r X codes up front and 08-10 rear leafs with 2 modded leafs added from the original pack .
But the orignal issue is not the 7.3 being a big heavy beast. Its no more than the other diesel offerings from other manf. Its the total POS quality of Mexican produced steel combined with the compromises they chose to loose 1-2 inchs in over all roof hieght for the soccer mommies.
