Stepped away for a while
punkrockford
Ok after the TCM failure I got discouraged and freaked out..lol After thinking about it, and seeing that a 6.4L won the diesel power challenge, again! I realized I owe it to the blue oval faithful to finish my truck the way I had originally intended. The build is back on!
punkrockford
It is not a crazy build by any means. Just looking for 500 to 600 rwhp. i want a reliable tow rig and a truck I can run down the track every once and a while. Plus the suspension upgrades via Icon Vehicle Dynamics. I have the Spartan tuner. Next is a Banks intercooler and egr delete once my warranty is up. what ever it takes to get to the hp numbers i am looking for
Jeff@Spartan
Georgia
You already have 500 horsepower. Like Scotty said, with a 71mm and some No Limit goodies, you'll be over 600 horsepower with a big tune.
punkrockford
do you have to replace them both or can you just add the 71mm?
what kind of pressure gains would I see and will it spool up faster?
I would also assume that head studs would need to come first?
webb06
Seneca, MO
You can just replace the low pressure. I've heard it spools faster than stock and drops egts a lot. Id recommend studs
