Stock injectors
Lang
Who sells them? Does ford sell them new still? Any vendors? Or reman only option? Any recommendations?
Craig@MFI
We can hook you up with remans with or without new solenoids give us a call
410-354-0340
golfer
Justin@DP-Tuner
We can get you setup with brand new Alliant Power (OEM) injectors as well. They will be coming from Tim @ P.I.S. You can also upgrade to brand new Alliant Power AC code (single shot) injectors as well. They are higher output and more efficient than stock AD code injectors.
Check out all the new injector options HERE.
DEEZUZ
NO PUKESTERS
NWI
OK I wasn't sure if it was something tuning takes care of or not
DEEZUZ
NO PUKESTERS
NWI
I did. When I put all 8 AD codes in, I had a small tap from cylinder #8 once up to temp. I then put an AE in there and no more tap. These are all brand new Alliant's too.
the kind fo tap you only notice when parked next to a wall type thing? I haz that... The FRX didnt fix it
