Stutter/shudder at WOT kickdown: transmission or engine ? Diff chattter ?
me2
2008 F350 6.4 5R110. Totally stock, 160K.
It cruises fine at 65MPH. Sometimes when I floor it to pass another vehicle it surges and studders like crazy. If I back off the throttle a bit it works fine.
Is this a transmission problem or an engine problem ?
I haven't changed the transmission fluid in 70,000 miles. I'm afraid to. I've heard they have a hard time learning to shift again, triggering a rebuild.
Also, I get a constant "jiggle" from the driveline somewhere. I'm pretty sure its the limit slip in the rear diff catching. I had this problem with my 1999 as well. I think it comes from turning sharp corners while pulling big trailers on pavement. Could this vibration be causing the transmission to have issues shifting ?
Thanks
when is the last time the fuel and air filters were changed?
me2
The air filter is perfectly clean. The suction indicator isn't getting set, at least not when I am in a snow storm.
The fuel filter was replaced about 30,000 miles ago. Its due.
me2
So, the TC is unlocked at 65 mph or locked?
I haven't hooked up a scanner, but it seems to be locked like it should be when cruising. I certainly doesn't feel like its slipping and the tach confirms that.
Mark Kovalsky
SE Florida, USA
I believe it is an engine problem.
That's a new one that I've not heard before. It's not true.
If the vibration gets into the transmission and affects what the output speed sensor (OSS) signal looks like, then yes, that will affect the shift.
