Surge at idle when warmed up.
V-Ref
9 miles high @ 550 mph
Does it idle same/worse/better without your F6?
Do you have a high idle tune....how does this operate cold vs warm?
Compare ICP/PW on AE during the cold/smooth idle against the hot/erratic idle. Talk to your tuner. He may be able to tweak a parameter that will fit your truck, if you conclude that nothing is wrong with your truck.
907DAVE
AK
:whs:
If your ICP sensor is leaking oil up through and into the connector you need to change it, could also be your issue.
Justin@DP-Tuner
It idles the same regardless of if I have it on stock or on any tune. I do not have a high idle tune.
Everything seems normal when hooking it up to the AE. The AE shows that the idle surge is only 50 rpms.
