Switch on the Fly for SCT is Here !!!
bigrpowr
<How I Fly
Administrator
15-16 currently , 11-14 should be done in the next few days. Uses the S P A R T A N switch and actually has adjusted transmission tuning for each power level. Available on the X4 and the Livewire. add $200 to standard retail pricing, cost includes the switch !
Powerstroke Man 6.4
Nice, I knew it was a Spar-tan switch when I first saw it.
Great quality, plug and play and best of all looks factory.
8WR_ZJ
Whos tunes? All of them that are ez lynk?
08Monster
Now I'm definitely interested Mike... I'll text you.
Sent from my XT1585 using Tapatalk
8WR_ZJ
I ordered mine I shall report back with results shortly.
15 F350 CCLB
8WR_ZJ
Question do you have to be at idle, steady cruising, or engine off to switch positions? Is there a high idle? How many positions?
Rueben1988
So is it possible to have a tow power tune with a tow trans tune and once you switch to a race tune does it also switch to a race trans tune?? And are the SOTF power levels the same as H&S where just the pw is changed or does the timing or other things
also change on different power levels? Does the livewire have to be plugged in to use the SOTF knob and is the knob compatible with the use of Edge insight pro as a monitor?
