Sxe 366 boost port??
jtlane
Where can you find a boost sensor for a sxe366 or does people just cover them up?
superpsd
Missouri
I assume you mean the speed sensor port. The port is there but not drilled thru. To install a speed sensor light Machining is required. If you are not installing a speed sensor you do not need to plug anything of course.
rusty1161
Whittier, CA
I have a boost sender fo my Isspro gauge installed in my SXE. I had to drill the port thru and the 1/8” pipe thread sender fit right in.
Rusty
