terminator dual hpop install
hwrdbd
Anyone have some good pics of how the lines are run for a terminator dual setup? Can't seem to find his website anymore and just want to make sure I'm all set before i rip it apart.
KBMKVIII
Texas
Hope this helps.
I used a dieselsite hpop spacer though.
Makes it easier.
Layson
No they are not the same. I can't remember how I did mine. I had to get another hose. That way I either had (2) driver side lines or (2) passenger side lines to make it work good.
hwrdbd
That stealth setup looks good. I'm mainly concerned with one particular port on the terminator setup. Currently I have a small allen head plug in it, on the top passenger side of the terminator coupling block. I've googled a bunch and I seem to find a bunch of pictures showing it plugged just as mine is, but I also seem to find some info about that being a pressure relief port that needs to be tied into somewhere as an oil drain? Thats the main deal I'm trying to figure out.
Magnum PD
VA
Are y'all doing an extra supply line from the oil line at bottom of engine?
MeTo
Is that a coolant filter on the front of the engine? I have never seen a filter in that location.
KBMKVIII
Texas
I have an additional resivor feed on the top from the oil gallery on the side of the block to avoid any oil starvation issues.
KBMKVIII
Texas
Yes it is the t444e dieselsite coolant filter/water pump.
KBMKVIII
Texas
I thought the terminator setup was different by using a billet block instead of a equalizer line between the pumps.
Not sure of exact differences.
You can do a 4 line feed setup, but it's a pita.
I had mine setup that way but changed back to a 2 line feed.
