timing maps
From what I've seen the main timing map should be configuration 0, temp 0.
I've done some logging and mine seams to be in configuration 1 for some reason. single 472sxe, 165 lp pump, fuel bowl/cooler is gone, I've turned the vgt off, and certain dtcs to get the cel to go out,
2jpwnBe
2jpAnao
2jpz9sv
I know about the coolant temp. My fuel press maps work in con. 0, temp 0
My iats were between 70f and 100f when I was making the logs, I did find the map for "iat used in map selection", not sure how the 1-8 correspond to the timing configuration/temps
messin wit this again Based of an hd300, It never seems to be in configuration 0, temp 0. Maybe 1,2 or 1,3. I copied my 0,0 map to config 2 and 3 and it went to 4,3 , full derate +10° timing.
