Towing with a 6.0
Gainesville Ga.
Definitely an improvement from a similar modded 7.3l. Now, with 7.3l I could tow an any tune as long as egts were kept in check, assuming this is the same for 6.0l especially since I now have a tow haul mode to take care of shifting no matter the tune, is this correct?
Sent from my VS985 4G using Tapatalk
Gainesville Ga.
What's too high and normal for oil and water temps? Towed yesterday in Looney wild tune, egts are definitely not an issue, max oil temp was 208, and water about 210, trans never got over 160. Just towing about an 8000lb TT
06-6.0l, studded, reworked heads, egr ******, blue spring mod, 6.4 banjos, dummy plugs, stand pipe, upgraded stc fitting, New oil cooler, New ipr, New icp, atlas 40 FICM, stage 1 powermax, and Looney wild, 325/65R18
