Trans acts weird when cold
protraxrptr17
06 f-250 sct with some custom tunes. Also has tuned FICM and 5" flo pro. I got the tuner used from a member here. Don't remember whose tunes they are. I use the extreme street one. If I let the truck sit all day, or overnight without plugging in the block heater, the trans goes nuts on the first few shifts. It flares and jerks back and forth between gears. I can let off, and ease back into it and it will catch up. After a couple times of this, it straightens out and does ok. Just started this about a week ago. If the block heater is plugged in, it doesn't happen. Any ideas?
Lassie
Tenn River Alabama
It's not your trans. Injector stiction is what you have. When truck is cold, it's not making the power it should and the trans shifts are late, rough, etc, etc.
Zmann
agreed not trans related because it goes away with the block heater
and the theory that the warmer coolant is heating the trans fluid in the radiators fluid to fluid trans cooler doesn't work since the trans is bypassing the cooler until 180*
protraxrptr17
Engine runs smooth as silk. Even cold. Starts right up hot or cold. Definitely not stiction. Im sure it has something to do with line pressure when coolant temp is below a certain temp. Not a trans expert but its definitely transmission related.
constantfix
NJ
Try going back to stock setting and see if the problem goes away.
The why and how, I havent a clue...but the same thing happens on a tune or two that I have. If I go to stock setting, rough shifting goes away while truck is cold.
I just live with it and feather the pedal, until truck is up to temp
Zmann
When I had light stiction and finally down 2 injectors I swore it was My transmission
Lassie
Tenn River Alabama
Yep, the first time most experience stiction, they'd swear they're losing a trans. Just finished putting a set of eight in a truck that started and idled as smooth as any. When she was throttled cold, RPM would get to 3000 and wouldnt shift until you let off. Cold natured as hell. Eight injectors cured his "transmission problem". The block heater part is a tell tale on yours.
constantfix
NJ
You know what guys, im going to stop offering suggestions & just listen.
I guess im going to be shopping around for 8 new injectors haha
I recently had two injectors removed & replaced (155's)...my jerky/ bucking /engine lugging went away (45mph & above)...but I still do have what the op was describing..I really did just think it was a tuning quirk & didn't consider any bigger/ underlying issue..especially considering it went away once warm
Crap
Zmann
you could always give one of the stiction chemicals a shot
Rev-x
Archoil
HotShots
MorganY
college station, tx
Your block heater has no effect on transmission temperature. None. The trans temp is the same whether you plug the block in or not. And if the problem goes away when warm, or if the engine is plugged in, it is engine related....i.e. Injectors
You have a miss. Take it to someone with IDS or AE.
JGman141
Ohio
:whs: I had the same thing happen to me. I had 2 bad injectors that were making the trans act stupid when cold.
protraxrptr17
I appreciate the suggestions, but its not missing. The trans SLIPS. I know what wore out injectors feel like and this ain't it. I know there are some changes the TCM makes to shift points and timing when coolant temp is below normal. This is the connection to the block heater. I feel like I have a small trans problem that is magnified by the programmer and tuned FICM. This problem started a week after I put on the FICM. What exactly does the "tuning" do? I can't really tell it made much difference in power, and it may be causing this problem also.
protraxrptr17
Well, checked trans temp before start up this morning. Block heater plugged in all night. Ambient temps in the low 40s. Trans temp was a toasty 84 degrees.
Pizza pig
MD
Its not the trans slipping. Go do a power balance with an ids and it will tell you which injectors need to be replaced.
Zmann
Like mentioned the block heater had no responsibility for that 84*trans temp it either didn't sit long enough or something is up
Mark has it right Your hell bent on the tranny being the issue and nothing else can sway you
from what I remember the cold shift gear select strategy isn't even in play here as far as I recall the temp must be much lower so?
Mark can clear that up maybe it does do some shift strategy it doesn't use the variable gear ?
IDK but good luck
Mark Kovalsky
SE Florida, USA
When the trans is colder than 0°F it will shift 1-2-3-4-6. Once it is warmer than 0°F it will shift 1-2-3-5-6.
A block heater WILL warm the transmission somewhat. I've tested this in extreme cold. We had to get the trans cold to do cold weather testing. If we left the block heater on all night the trans wouldn't get cold enough. We let them sit overnight without being plugged in, then plugged them in about 2 hours before we started them. The trans would stay pretty close to the temp it was at when it was plugged in, but the engine warmed enough to get it to start.
protraxrptr17
I just read part of a 15 page thread on powerstroke.org about 3-5 shift flare. That is exactly what my truck is doing. Kovalsky was mentioned there and maybe even replied. I havent read the entire thing yet. The slipping/flaring only happens on the 3-5 shift. Can I get any serious input or help now, or do I still have to listen to this injector BS and being treated like a total newb?
Zmann
so yours is cold shifting at 40*?
