trans cooler
PA Stroker
Sweet Valley, PA
I'm buying a bts off a member and im wonder whats the best way to clean out my trans coolers. The trans i have in there now is smoked and i know the coolers are filled with crap. i dont want to just scrap them because i have a 6.0 cooler already and there kinda of expensive to buy a new one. Another questions is should i just bypass the rad trans cooler?
Mark Kovalsky
SE Florida, USA
You should NOT bypass the radiator cooler. It does a very good job of cooling the ATF. I do not know of an effective way to clean out a 6.0L cooler. I would not reuse one of those after a trans failure.
PA Stroker
Sweet Valley, PA
what should i try to do to clean out the radiator cooler? It will be out of the truck anyway. I have to pull the motor and fix the oil pan.
PA Stroker
Sweet Valley, PA
Thanks for the replies. I think thats what I'll do and just put a filer in and change it a few times. Would brake clean work well to clean it out? Also what kinda of filter? Would just an oil filter on a filter block work?
Diezel Dawg
Cheney, WA
