Transmission Code P0713
Whitetailfreakz4
West Virginia
Alright, so was driving home last night, and the trans gauge temp was maxed out, check gauge light was on, and the tow/haul light was flashing. Was in 4wd but running normally. Truck seems to be running ok, tranny hit a little hard when the gauge topped out but that's all I noticed. Fluid levels are fine. Any idea what this may be?
Whitetailfreakz4
West Virginia
Ok thanks. One more question is it ok to drive it like that for a bit until I have time to tear into It or will it causeore probs! Thanks In advance
Koda22
Ruidoso, NM
So pulling up an old thread....is this an easy fix? Also is it a big problem or does the truck need to be shut down till the fix? Last is it a cheap or exspenive fix?
Mark Kovalsky
SE Florida, USA
