Tri compound
Rpbobby492
I've got a crazy idea of using 3 turbos but running like a traditional compound setup but instead using a s366 66/74/.91 high pressure turbo and using 2 low pressure turbos s472 72/87/1.0 and s488 88/96/1.32would there be any reason why this wouldn't work
Zeb
Downtown Marrowbone Ky
Don’t waste your time. :)
Packaging compounds on a 6.0 is bad enough, a 366/488 will make enough power to scatter plenty of parts, and you wouldn’t gain anything worth having if you put the 472 in there.
Mesa, AZ
What zeb said. Typical compounds are a **** show under the hood. Triples are pretty much race only, as you lose a ton of stuff to fit 3 turbos, a 3 stage compound setup would be a nightmare.
For instance, typical injector swap is a couple hours total on both sides, with the compounds, it took me around 3 1/2 hours to pull my passenger valve cover when I had cracked nozzles... Plus I have to pull the hot pipe to change oil, as it sits right above the oil fill... Its a disaster...
