Tuning
F
Floorboard79
Guest
Maybe got lost in pesos to dollars conversion
Your avatar is mesmorizing
How about the 6.7 trucks our military uses with the 6.7, maybe they are 440?
F
Floorboard79
Guest
If they have the same rating i would think the dyno results would be close, sae tests use full exhaust system and accessories i thought. Wouldnt they rate the export file say 460 and 1000 if it made more power?
Doesnt matter anyway
Patiently waiting for more tuning!
1bad6.7
Well I ordered a ****** kit on my 17 platinum, one question, Can I leave the egr in place with out unplugging anything or putting in block off plates without damaging anything?
bigrpowr
<How I Fly
Administrator
yep !
F
Floorboard79
Guest
Mine is tunning great as well
The delay in theottle response before boost is annoying, also the mog seems about the same, im noticing the timing runs more retarded than the stock tune. Also the egr is showing between 4-7%.
Not sure if thats correct or false. Which 3 connectors do you un plug?
