Turbo discussion thread
Dzchey21
wyoming
Keep this one on topic too. Post info about turbo set ups, list fuel mods but dont get crazy. Post what you can, boost/back pressure, turbo size(s) mouting and uppipe manifold combos. Also if you can report where the turbo makes boost IN OVERDRIVE WITH the converter locked, and even post a speed, that way people get an idea how driveable it is ect. As always track times, and dyno graphs are greatly appreciated, keep it on topic, and keep the questions limited as most of these combos have threads already.
Also it may be helpful at the end of your posts to link the original build thread to keep things simple, this will hopefully give people a good place too look.
THanks
bigrpowr
<How I Fly
Administrator
this should be a hot one... ill let the others post their own info, but the turbo market is so fricken awesome for us right now.
stock fuel, high power turbos, (76mm BB PTE and 63mm elite VGT) .... 646/1252 DJ uncorrected at less than 1k feet of altitude. 12.52 @ 106 at 8300lbs ... trap speed calc says 675.
maybe we can make a list dustin , not in order of hp, just what each configuration has made for reference.
Dzchey21
wyoming
Im fine with that. Probably a good idea. Like tow powers stock fuel tow powers 110s Ect
Good call as more roll in ill copy and paste into the original thread
Sent from my DROIDX
Craig@MFI
Double Batmowheel 75mm s400....890hp uncorrected....11.34@122
100% nozzles and rudys dual pumps with airdog
Mike@MPD
Pasadena,MD
The 72 on mine is not a batmowheel wasn't lucky enough to get one
Sent from my Droid Charge using TAPTALK
08SUPERKING
Just as a question can mpd 475 battmowheel get made up to a moded high pressure stocker.... Can something like this be possible to make up....
thanks,
08KingRanchF250
wallburg, nc
S472 batmo 72/83 with a .9 a/r, stock fuel and standard h&s HD for now made 660/1166 on rudys dyno and went 7.84 at 88.5mph with a 1.74 sixty at 8100lbs
