Turbo sqeeling sometimes.
Dzchey21
wyoming
Under hard boost?
Most likely its the pipe between turbo or the gasket on the exhaust side between turbos
Dzchey21
wyoming
Chances are its a wheel hitting the housing. Pull the intake off and see if you can move the shaft
Mike M
Illinois
Sounds like the beginning of wheel-to-housing contact. Does it do it right off idle, say when thrust is first applied?
Dzchey21
wyoming
Could be the high pressure. Shouldn't make any noise how long has this been going on?
idkillinit
North East, MD
Hmm. Idk how long time but its Prolly 3000 miles. Notice it the most under acceleration. Does not do it when start up.
BOOM
Dustball8504
Everett, PA
Are you sure it isn't wind noise? My truck will do this when its cold and windy but I read up and its just the window seal. I noticed it with both sets of turbos I've had on it so I ruled that out right away.
