05wh250
Im putting a set of components in my truck and plan on mounting the tweeters on the sail panels. My question is do i need to angle them to the center of the truck? Or at the front seats? Or where?
point them toward the passengers/driver.. technically speakers are not suppose to be pointed at each other due to the waves hitting each other head on messes them up versus deflecting of each other
So the drivers side should be pointed at the passenger and passenger be pointed at the driver?
i meant you not speaker driver sorry.. but like everyone says play around to see what you like. as a general rule point them toward your head if you were sitting in the seat and make sure there not pointed towards eachother. and use the closer driver for the closer seat, less sound waves crossing so it will be clearer but i doubt you would notice that much
