Upfitter switches
Mesa, AZ
More or less. I believe ford sells a kit to add them. Comes with the relay box and switch panel, as well as harness to connect them. Cant remember the part number offhand, but done a few at work. I believe it comes with instructions as well as to where the harness you plug into is located and whatnot
Cypress, TX
I agree and have found everything you said. Just was wondering if an XL had the plug that the kit plugs into on the firewall.
I have done a couple also but not an xl. Shouldn't the harnes already be there just plugged into a dummy plug?
All models should have the same wiring harness. It just depends on the module or relay and or switches right?
Mesa, AZ
Yeah, it should. I dont remember if I did any xls, I would assume so, as most have been city work trucks, and I dont see them spending anymore than they have to on a vehicle, unless its a supervisors or something.
Cypress, TX
My problem is the cab is up on the lift. If I lower it down I don’t know that I can get in there to where I can see.
I question it because from all the research I have done I can’t just add power windows and such because the harness is different.
Guess worst case I could just make it work.
james_mtz07
Sorry to hijack the thread but does anyone know what these wires are under the dash in the same general area of the Upfitter wires? The pic is from a 2011 lariat.
dsberman94
Pennsylvania
There’s a bunch of write ups on the in inter webs for installing upfitters in trucks that didn’t come with them. One I saw used the factory switch panel but the guy made his own relay board. Others use the OE switches and relay board. And I believe I read something about there being a wire missing in the back of a fuse box. you take your upfitter relay board power wire with the pin on it and put it in the back of the fuse box for power at a certain fuse. I did read all this for f150s though and I thought I had them saved but can’t find it.
