Upgrade suggestions
loganhorse
Looking for the right route to go with my truck. I currently have the transmission out getting a stage 1 sam wyse. So while it was out I was going to do bellowed uppipes, 360 rebuild, KC S3000 turbine, KC billet wheel, ******d outlet, ******d pedestal and possibly HPOP lines and 4 line fuel feed. Would this be a waste on stock injectors and should I have any worries about factory head studs? I really have no plans for injectors unless one fails someday.
Thanks for any input. I'm new to the diesel building word.
PS. already have hydra and gauges. Forgot that
Swaan
I think all that would be great. No not a waste on stock injectors. It will still run more effficiant with all that on there.
No need for studs with stock injectors. I'm a big adrenalin hpop fan. If you can afford it there a nice upgrade also.
I doubt you need the 4 line feed but a regulated return would help inj life a lot.. i second the adrenaline hpop.. dam good hpop.
