UVCH question
freddie
Ohio
New vs old UVCH harnesses. Both Ford brand. I noticed the new harnesses don't have the brown connector seal - is this normal? They were new in package. All 4 UVCH harnesses are missing them so I assume that's normal
Parker, TX
Yeah, the old ones with the plastic holding tabs used the seals. The later units with the "bail wire" clips don't use seals. You don't need them when using the newer UVCHs (and they won't work if you try to put them on the new units). Cheers!
freddie
Ohio
Thanks!!
