Valve seals...
CSIPSD
Bend, OR
What am I going to gain if anything by replacing the valve seals? Less blow by? Compression? Anything?
Should have done them when I had the motor out, but was in a hurry and so...
SDstroker
SE, SD
Are you talking the ones under the valve springs? If yours are leaking you will burn less oil I suppose with new ones.
golfer
we don't run valve seals on our high-ish hp engines...
the only time a (turbocharged) diesel would 'suck' oil through the (worn or non existant) seals would be at idle...if then
valve stem wear is pretty ridiculous on these engines...so removing the seals can increase lubrication of the stem...which is also why even our "stock" engine's get bronze valve guides...
less wear...less valve stem/valve face "rock"..a more square seating for the valves/seats...more longevity.
CSIPSD
Bend, OR
So would a motor with around 250k on it and unknown history for the first 180k be a good candidate to just leave it the hell alone?
KBMKVIII
Texas
im going to attempt these while changing out my valvesprings and pushrods.
any vendors on here that sell them?
OSCS
Houston, TX
I'm curious to know why a turbo diesel won't suck down oil at the seals but gasses do?
Hotrodtractor
Mingo, Ohio
Well.... one has a constant and varying vacuum on the intake runner typically (gas engine) - the other might have a vacuum at idle, but it quickly becomes neutral to positive pressure as the turbo comes on... (turbo diesel) without the vacuum there is nothing in the intake runner to suck the oil down out of the head. Its really more of a difference between naturally aspirated and forced induction - but most gas engines that people are familiar with are naturally aspirated and most modern diesels that we care about a forced induction.
OSCS
Houston, TX
Thank you
