Power Strokes
6.4 Aftermarket
Warranty Question
[QUOTE="Big Angry Hillbilly, post: 464184, member: 4453"] Wrong. There are CARB approved programmers, and the underhood label CLEARLY states that if a failure is caused by the tuner, you pay for it. You mean to tell me that if I tune my 6.4 and the radiator starts to leak, they won't cover it? However. A dealer reserves the right to refuse to work on your vehicle if it's modified. THAT BEING SAID: An FSE sees that you've done this? They will cancel emissions warranty on your vehicle because you've removed smog components. To allow the vehicle to operate with removed smog components, you need to alter the PCM programming. Bye bye powertrain coverage, because you're running non-Ford programming, unless you've figured out how to make the Emissions level show up as "OTHER" on the IDS ;), which is Ford programming, but still not legal for highway use. [/QUOTE]
10R140 failure
Latest: PSD-BLACK-CLOUD
Yesterday at 1:04 PM
2017+ 6.7 Aluminum Super Duty
2010 headunit
Latest: glog
Wednesday at 1:17 PM
6.4 Tech
D
Latest: donaldtfreeman
Tuesday at 10:43 AM
6.0 Tech & FAQ
Latest: Tiha
Tuesday at 8:07 AM
7.3 Tech & FAQ
Latest: ju015dd
Sunday at 7:59 AM
6.0 Aftermarket
Power Strokes
6.4 Aftermarket
Warranty Question
