What turbo do I have?
Going to do an EBPV ******. Since this is an “early 99” E series, did it come with a bigger turbo from the factory like I have read and I need the 99.5 kit or?
ghohouston
Lewisville,Texas
Early 99 van turbo. Those "lines" if you will, around the compressor housing, are only present on e99 and obs turbo's. You can also tell by the 2" intake plenums, vs the later style had 3".
T_W6.7
Montana
it won't open due to the software that thinks certain words are bad words and it automatically changes them to *****
ghohouston
Lewisville,Texas
Do I not need the new exhaust housing?
No. Cut out your ebpv valve, and pop 2 freeze plugs in. I think actually, if you cut the valve shaft enough, you can leave the bottom plug thats already there, and only need to get 1 freeze plug. Or it's the top one that can stay, been too lomg since I've done one.
