Wheel Hub Ass.
JoeDiesle
NJ
Replacing the front wheel hub ass on my 01 4wd, using Timken. 2 diffent parts#s, 1 says fine thread studs, and other says coarse threads studs. Which one will I need. 165$ diffent between both.
jvencius
Get a thread pitch gauge, measure the studs on your other hubs, then buy the hub assembly with threads that match what you already have.
NotStock
Tucson, AZ
Chances are it will be a fine thread but you will want to check to be certain. You will also need to know if it has front ABS or not. That may be part of the price difference aswell.
co04cobra
WV
Its course thread. They started fine thread iirc in 03. Hope it helps.
