which wheel bearing
n54power
I'm trying to figure out which timken unit bearing I need.I know I need the one with abs but timken lists like 3 doffered part numbers.
coarse thread,fine thread.
look at the threads on your wheel studs.. see if they are fine or coarse...
n54power
Course?
POWER-STRUCK
Indiana
Take a wrench and use it to measure the thickness of the flange 10 or 13mm. Most everything pre 03 had coarse studs and check to see if it has a wheel speed sensor. Year also helps
eng53ine
Ohio
Take a nut to the store with you
02 ccsb, lariat, 7.3 auto, 4x4, 4" duals, 6637, IH bellowed up pipes, RiffRaff billet wheel.
