Power Strokes
6.0 Aftermarket
Who sells aluminum oil fill caps?
[QUOTE="Lilpooh, post: 828344, member: 7055"] Well since you have access to a lathe, make your own oil fill cap. The threads are 1.250 x 7 thread. For the filter adapter, the restrictor hole is .043", this will allow oil flow thru the filter at 1qt per minute. I've made two different style oil fill caps, one style is solid billet, and the other is 2 piece. The two piece has a aluminum top with a nylon insert, the insert is pinned with SS spring pin. [ATTACH=full]120306[/ATTACH] [/QUOTE]
02 F250 7.3 Will crank, WTS stays on, no start, no OBD
Latest: Sterling6.7
Yesterday at 9:04 PM
7.3 Tech
2015-2019 6.7 HPFP New In Box
Latest: lincolnlocker
Monday at 1:26 PM
Engine and Drivetrain
First 6.0L (56k warning)
Latest: adrianspeeder
May 26, 2026
Extra external motor oil cooler?
Latest: justinlogue5_0
May 26, 2026
7.3 Tech
Weird Electrical Issue
May 26, 2026
7.3 Tech
Power Strokes
6.0 Aftermarket
