Why a E99 Spyder
Spud Monkey
Quilcene WA
Keep reading post of people needing a E99 Spyder for OBS intercooling add on and was wondering what is the reason versus taking a regular for 99+ and putting it on?
co04cobra
WV
2in plenums vs 3
E99 is the easiest without changing anything else.
bluedge8
Champlin MN
the other option is to switch to the "super duty" set up, turbo mount, turbo, up pipes, possibly exh manifolds, intake plenums etc.
rat49f6
Vernon,NJ
I would go to t4 before sd stock set up
Sent from my SGH-M919 using Xparent Green Tapatalk 2
Spud Monkey
Quilcene WA
Just trying to get intercooler setup started first before I go that heavy into changing things around again as I just got done going with TS 6 chip, aFe intake, Beans turbine housing, EBPV delete with pedestal with it deleted, 4 inch turbo back exhaust and a WW2. Just need to find me a E99 spyder somewhere I can do the pipes myself.
old man dave
Petaluma, CA
If you were to buy the SD stuff new, the cost is far greater than going with a T4 setup and the only turbo upgrade would be a GTP-38R if you didn't want a factory based turbo.
