Windshield washer not working
K11ng_Ranch
Hey guys new to the forum, and new to fords. I recently traded in my ram 1500 Lonestar for a 2011 Ford F-250 king ranch. My problem is my windshield washer isn't working. I can hear a click when I push the button and the wipers activate but nothing comes out of the nozzles. Does anyone know how to fix or have had the same issue? Thanks in advance!
bunkerb
Pop the hood and look for fluid on top, I've broke 3 nozzles on my 2012, got told it's a pretty normal thing, enough so they keep a lot of them in stock...
Arconalloy
Warner Robins, GA
That or they tips are packed with wax or something it's happened on my vehicles before hit them good with the pressure washer if ya can't find anything broken or any lines leaking
K11ng_Ranch
Ok I filled up the tank and it's not leaking, I'll check the nozzles tomorrow and hopefully it's an easy fix
Mesa, AZ
Broken jets are most common as stated by bunkerb. If one isnt, check for rodent damage on the line. You can see pretty much the whole line down to the bottle, and since its post pump, it wont leak until the pump is running.
jwalk09
VA
Check for a kink in the line . Had the same problem and that's what it was. Locate the hose on the passenger side and before closing the hood push it down in the clip that keeps it lined up
