superduty prerunner project
Cutting-Edge Diesel
Newkirk, OK
Looks like the motor for the pro stock mustang will be ready sooner than I thought. So this project will be put on hold till I get the car going. I want to have time to finish it once I start so it's not setting in the corner for a couple years like the last time I tore into it for major work.
gfulton
Eliasville, Texas
Is that build on PSA ??
Have you been happy with the pin tops overall? I'm thinking of buying the 2.5kit as I tow a ton.
Twinturbostroker
El Paso, Tx
I wanna be like Matt when I grow up I've decided..........
So, when you selling your carli kit off your truck? I assume it's only "lightly used"? Lol
I'm really thinking of the coil over with a bypass in a 2.5lift. I'd regret it later for not getting the better kit. Plus makes it easier to just use their coil buckets since I need some for a leaf spring truck.
Cutting-Edge Diesel
Newkirk, OK
Got the new oil cooler mounted
