The 2011-16 Leveled Super Duty Thread
Profuzz
OUO coil spacers are adjustable for that reason
UNBROKEN
I'll take a good spring over a coil spacer any day. Tried that...hated the ride.
jwalk09
VA
yes i added those spacers 2 of them on each side. honestly i measured both sides and it sits i think 45in on both sides. but from the factory i did notice the driver side lean and now it doesn't lean so idk lol. i just need to get it aligned now.
The spacers just sit between the coil bucket and the rubber piece on top of coil right ? They don't bolt in or anything
macsfx4
correct. and i just noticed i was looking at my factory sway bar in the front and saw the driver side end link pretty stretched and the passenger side straight is this normal
UNBROKEN
That's what I did. To be fair I don't think that's what PMF had in mind with those spacers. The have bolt holes in them that match their top side coil spring spacer. Mine have been in for quite a few thousand miles now though and haven't moved a bit. I marked them and the coil bucket with a scribe and they're still right where I put them.
UNBROKEN
Mine were all jacked up at first. PMF drop brackets fixed the stock bar but when I switched to a Hellwig Big Wig front bar I had to remove the drop brackets since it was making contact with something....can't remember what. Removed those and everything is back in place. Must be some differences in the bends between stock and Hellwig.
macsfx4
Do you know if leaving the stock sway bar and having the driver side one at a pretty harsh angle hurt anything?
Gleebag
Kansas
Fox 2.0's
PMF dual stabilizers
PMF 3-link
PMF Trac bar
OUO bars
Icon 2.5 springs
did you mean to say that you couldnt handle the stock ride? There should be no change in ride by adding just a spacer. The two things that could affect ride when the spacer is installed are caster and shock length. Both those things have an effect on ride.
UNBROKEN
Hated the stock ride, period.
Love the front now with the Icon springs and Fox 2.5's. I can live with the rear with a block and 2.5's. I know I'd love it with a full leaf pack but I don't hate it enough to spend that much money on it.
Cpstanley
Fox 2.0's
PMF 3-link
PMF Trac bar
OUO bars
Icon 2.5 springs
Looks great!! Is that their PMF's 2.5" kit? If so, what is the ride like? What tires/wheels are you running?
jwalk09
VA
Mines like that also. Not sure why
jwalk09
VA
So did the hellwig bar also straighten up the end link angles even after removing the drop brackets?
macsfx4
hey guys I've noticed a thud noise if you would call it when turning my trucks a 2015 2.5in icon coils, pmf 3 link, 4in block, i re tightened the ubolts, wheels, went over everything and only thing i found was the heim joint on the 3link the nut was loose and the join was cockeyed so i straightened back out and tightened the nut back but noticed on the icon track bar was cockeyed and on the passenger side is pretty steep angle almost hitting the axle can anyone verify that everything looks ok
strokin20
brownwood, tx
I just happened to check mine out yesterday morning and my track bar was in the same position against the axle. I got to messing with it, and found that one side of the collar that joins the heim to the bar itself was somewhat loose. You might check yours and make sure they are still tight. I've got the Icon adjustable bar as well.
