MCC for 6.7
6.0L Stroker
Southern Illinois
I am looking forward to these tunes as well. I rode and drove whynots truck and it felt really good to me. Shifts were smooth and firm when you needed it.
Sent from a lawn mower
Elliott6.7
I am super happy with Matt's tunes. They feel strong and the shifting is awesome. I'm sure they're right up there in the HP heap, but most important to me is the good manners and driveability on the street. I've towed about 8,000 lbs through some hills and the truck did great, egts and boost stayed in check
Sent from my SGH-I337M using Tapatalk
Gearhead
Done.... had a stock 14 with dual pumps only put down 541 to the wheels at Ennis.
Gearhead
Nice! What are your capabilities as far as trans shifting? Can you create a tune that bypasses 1st gear when not using tow haul?
Can make it shift really early but not eliminate. What's the issue with the factory shifts?
superstroked
Celina, TX
With the 4.30 gears, 1st gear really isn't needed when unloaded. I have been messing with the manual mode starting in second and it seems to be more in line with what I like. Also, the 1-2 shift feels really slow to change. Maybe thats what I need, a little more snap in the 1-2 shift.
I really like that these transmissions lock up the converter in the lower gears too all the way down to around 1100 rpms in gears 3+. Could it be set up to do it in second gear as well?
Thanks for your time with this and what all platforms can you tune the 14s with?
Gearhead
14s are covered. I can change the shift timing if you don't like what I send you.
bigbrdf250
I'm interested for an 11 model. I called Friday and left a message for Larz?? Get back with me and what info u will need from the xrt. Don't know if I'm taking my truck to work Monday so before hand might work. Getting my pipe in Monday too. Yay!!!!
drunk on diesel
they'll need your VIN number
you'll need to purchase an MCC code for your truck off of the H&S website or from a supporting vendor (the H&S website is fastest IMO)
