superstroked
I will probably make a decision based off your findings...thanks for being my guinea pig ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I will probably make a decision based off your findings...thanks for being my guinea pig![]()
Ordered it last week Should get it this week, saved about 80 bucks with the thanksgiving sales...lol
Ok so after I had issues with UPS I finally picked it up from UPS Friday, I had a chance today to put it in. I will say the instructions are clear except for the tee tap on the brake switch wire. I ended up removing the brake switch for better access to the wire.
Now for the results, this information is based on the truck empty with a truck weight around 8900-9000 lbs
The rotary switch offers three different modes:
• Stock
• Vane Control Only
• Vane Control and aggressive downshift
The number one setting Vane Control Only doesn’t seem to do much driving around empty. I actualy didnt even notice it on at first. After playin with it you just dont see much on setting 1 unless you are in the upper rpm range 2500-3400, in that rpm range you can fell it work and the back-pressure is around 52-64 psi actual or about 78 on the dash daq. To get these numbers I had to run third gear to about 3400 and let off the throttle.
Now setting 2 Vane Control and aggressive downshift is a diffrent story, this setting is VERY aggresive the truck down shifts very aggresive as soon as you let off the go pedel and the exhasut back pressure is in the 58-68 or a max reading of 82 on the dash-daq with a rpm range of 2500-3400. The truck slows down really fast. From about 55 mph the unit did all the work I dint have to manual shift at all to get these numbers, all I had to do was let off the throttle
Overall the unit seems to work as intended. I will add that I was running the Spartan 275 tune while running these tests. The only negative thing at this point I can comment on is the trans shift from decel to acceleration, I am running upgraded solenoids and higher line pressure along with a aggressive tune and a aggressive TQ but a few of the up shifts out of a decel where harsh almost similar to a rev slam. I had two notable hard shifts when I got back on the go pedal after a fast decel, probably not something that would normally happen towing a trailer but notable nonetheless.
Hopefully I can grab a trailer tomorrow and load it with 20K or so to come back with some loaded test results.
Another notable issue is if you don’t have tow haul mode on, if you select the number 2 setting on the exhaust brake it will engage tow haul on decel automatically and turn it off on acceleration. This is just the first day i played and i only had about an hour or two if that with it, tomorrow i can play with it more and provide more results loaded and un loaded or any other info yall may wanna know
If you are seeing that kind of back pressure, it will work great at slowing you down, even with the extra weight of a trailer. H#ll, running in the 40s of BP is enough to hold me back on 6-7% grades grossing 30k. Based on your reports, it sounds like this work great. The only question is will it last??? I hope it does...it would be really nice to have an option like this that you could turn on and off.
Are you on stock up pipes?
Yes I am on stock up pipes.
For my own clarification If I am not mistaken the EBP reading on the Dash Daq is absolute which reads about 14-14.5 atmosphere. That has to be subtracted to see the actual EBP.
I just want to be clear on my results thats why I stated on setting one the peak EBP on the Dash Daq was 78 psi after the correction that is a actual EBP of about 64 psi. This number is based on the high end of the rpm range truck did not down shift i actually had to bring it to the high end of the RPM range then let off the accelerator.
Setting 2 the peak EBP on the Dash Daq was 82 psi after correction that is a actual EBP of 68 psi. This number is based on the higher end of the rpm range as well but the controller did the aggressive downshifting to keep the RPM's up after you let off the accelerator.
Well just an update, I am very happy with the engine brake, setting one is what I use the most , setting 2 is simply too aggressive with the Trans mods I have done. The issue I have with setting 2 is when your coming down a hill and rpms are high around 2800-3400 it will slam into gear when you attempt to accelerate that is really the only compliant I have it after several thousand miles towing 28k to 32 k gross but I think it's has a lot to due with the upgraded Trans solenoids and aftermarket Trans tuning. It's amazing the grades i can come down with that weight and not touch the brakes unless some azz cuts me off....lol. I still use the number 2 setting in steep grades, but I select back to the number 1 setting before I accelerate . Hope this helps a few of y'all on the fence about this product.
Anyway you could possibly mount it around a wheel well opening or near the front so air can keep out cooler? Just a thought. I don't know where it says to mount it at.
Cory Anderson
