Non vgt s369sxe billet upgrade time. HpPredictions???
6 L chevy eater
Franklin, VA
the 369sxe come with 80mm turbines, which compared to a 472 with an 83 turbine, id say flow is close to the same LB per min. and ive been running hybrids dam near a year now and truck makes good power AND will continue running hybrids
04cr450
harford county, maryland
Charlie- I had a 64.5sxe prior to the 69 sxe and the power difference is noticeable but no where near the feel of a s472. The truck I rode in that has a 472 in it on only 225/100's and my setup had 205/75's so not that much difference.. the 72 pulls very hard up top compared to the 69 sxe.
Harleyx
T ville
Guys....holy fumbling shiz... even with the t4 to vband adapter... brake stall is so easy, spools right up even with stock intake, this is a bad mama jama, by buddy's gt40 truck with a 1800 charger doesn't come close, needs tunes witg later lock up but it burns off tires at 65 plus , 4500 rpm shifts, nasty sounding and spools better than I could imagine
Harleyx
T ville
So freaki ng happy with this setup... cleans up 340s at 1.6 ms pulsewith ... can't wait to Gate it and spray itm.. it's 700 plus easy right now
Harleyx
T ville
Ccv eliminator was clutch and not a single blown boot, measuring 60 psi over 79 psi bp
HOOV3R
Central PA
Still a 74mm turbine exducer on the 369 vs a 83mm exducer on the 472. The 472 will definitely have more flow up top.
Harleyx
T ville
I loooooove this setup big thabks to smeding diesel for the ho ok up 750 bucks on the 369 supercore and a housing from mikes turbo for 100 bucks, 850 in the whole turbo, made my own drain for 10 bucks, made my own feed line 36 bucks, and fabbbed my own pedestal with t4 2 vband adapter for 150 bucks, roughly 1100 in the entire setup
Six_Sloww
Southeast MI
Actually it's this strange pattern where for some reason when people list specs of the s400 they list the turbine exducer but when listing specs for an s300 they list the turbine inducer.
The s400 typically has either an 83/74, 87/77, or 96/88.
The 369 has a 80/74.
I forgot the s472 comes with an 83/74. I still think it would make more power than a 369 but until someone proves either way it's purely speculation.
6 L chevy eater
Franklin, VA
enough said:thumbsup:
Harleyx
T ville
I've always wandered the same. It's stupid
Harleyx
T ville
Rather have a s300 for the spool and borg th em selves said it will make more Cfm than the 472 lol I trust borg and like to drive my tru,k on the street could give a **** less what the difference is at wot between 3 mm on a turbine if I can drive it without smoking out the world duh lol
