d60 torque specs
zilla68
Moore Oklahoma
finishing up my ball joint job and need some quick help.
on the front hub, there is the outer bearing, spacer with notch, nut number 1, a keeper, nut number 2, then the lock out hub.
what do nuts number 1 torque to and number 2 torque to?
Parker, TX
Tighten the inner nut to 50 ft-lbs, then back off 90 degrees. Tighten the outer nut to 160-205 ft-lbs. Check the torque required to rotate the hub/rotor. Torque required to rotate the front disc brake hub and rotor is not to exceed 20 INCH-lb. Cheers!
Parker, TX
That's weird. All my factory service manuals (each year 94 through 97) specify 160-205 for the outer nut (manual hubs). Cheers!
m j
BC Canada Eh!
that nut is awful thin for that kind of torque,
I just tighten it up with my long handle snap on ratchet as IMO the torque doesnt really matter on a jam nut
zilla68
Moore Oklahoma
I know mine was pretty tight but I doubt it was 150-200 ft lbs and it had been serviced at the dealership years ago
