Build time! S400 style
617mach 1x
Alittle bodyshop tlc
Injectors are in, RCD 275/100 just missing my dual hpop setup to come in
617mach 1x
That before my cousins prom
My scrap pile
:drool:
Using the old atlas 618
I also finished up the manifolds, getting then decked by a friend then I'll have pretty much everything to finish up the truck
Other the a front locker
617mach 1x
Truck is running, sounds smooth as hell even with 275/100s, runs pretty good even wit a tune written for 190/stock and a stock turbo
Gears and locker tonight, still waiting on my tune from Jesse
617mach 1x
Damnit Kevin, that thing runs awesome! I think doing the 100% was spot on! Good work!
Thanks Jared! It sure did a good job, runs great! The injectors aren't full fuel I checked with my tuner on that I have plenty left over lol
I know running around on my tune for 190/stock and stock turbo I'd roll into it till about 8-10 psi and slammed on it, it would light up my 35s like it's nothing and burn till 3rd gear, it's even more power full and faster spooling with the right tunes now
I was 800 pounds light in one class compare to a sparten tuned 6.4 and he got me by 7feet came around added wieght to my truck and beat him by 71 feet, with that run in the vid of 391.57feet
I need a higher stall and built Trans this is on a stock trans and gearing, also need a front locker
617mach 1x
need more track speed? any ideas? im running 3.73 35x13.5 sst coopers
truck is also going in for some major modification again this winter going to be sick when im done hopefully :naughty:
617mach 1x
Yup, no hitting the limiter now but close not going fast enough down the track, have enough power for Alittle more gear right now that's for sure
What gear are you running with the 4.30s and 35s Jared?
I'm running 325/65-18 tires comes out to 35 13.5wide
Breaking Habits
Mapleton, Illinois
4 hi first is money
I'm 4.56 with 35.9" duals
