06 axle swap and questions
rusty1161
Whittier, CA
My 2001 10.5" swap into my 1997 F250 has spring perches that are 1" taller. I believe most of the 10.5" rear ends are this way.
Rusty
FrankTheTank
Cecil County, MD
I hear if you remove the obs flex line off the axle, the SD flex line will thread right into it. But just what I hear. May get you moving quick till you find what you need
kmanxj
Reed City, MI
I already cut the steel line on my truck. Assuming I can just buy the same fitting as the SD for the obs size line. We'll find out tomorrow when I got to the parts store
kmanxj
Reed City, MI
Parts plus had an adaptor to go from the 3/16 obs fitting to the 1/4 SD fitting.
I broke my VSS pulling it out of the 10.25, where is best to buy a new one?
kmanxj
Reed City, MI
I wondered about that. I bought one from car quest. I guess I'll see what it does and go from there.
Have you changed anything in your brake system frank?
FrankTheTank
Cecil County, MD
No. Just all the brake lines so I have no rust issues. I think the peddle is too spongy for my liking but I'm used to it now. Still stops great and much better braking vs the stock obs
kmanxj
Reed City, MI
I got the back end all together last night and took it for a spin. And boy does it stop awesome!!! I had to pull the wheels and found there was no brake pads. I'm sure glad I didn't bleed the brakes first. So I had to go get new pads, came home to put those on and on of the pistons in the driver side caliper was broken and falling apart. So had to run and grab a new one. Have to get the bed on tonight after work and my fifth wheel hitch back in and go pick up my camper and head out for the weekend. Rocking two different sets of rims and some new axle technology in the back and old junk in the front!
kmanxj
Reed City, MI
The brake pedal is a little bit softer than before, but I have felt way worse and it stopped on a dime compared to before.
