Stroked777
Damn man. I'm subbing to see what you find out. Hopefully it's just the hg
I am thinking it is. its pooched out on the outside back corner too. dont knkw if you can tell but that is a good 1/4 inch of gasket sticking out right there.Damn man. I'm subbing to see what you find out. Hopefully it's just the hg
I live on dirt roads and when coolant and dust mix, it makes dirty parts.
160/100's with fresh stock headgaskets and arp studs?
FWIW, we wouldn't warranty HG failure with 100% nozzles...not on a fresh build.
stock gaskets even with studs on a newly rebuilt engine are not reliable above 35psi.
take a 100k mile engine, do studs one at a time (bolt out, stud in, etc.) and it'll hold 60psi easily.
my guess is that you did pop a HG..and the coolant is seeping over to the threads.
you'll have the same issue(s) with another set of stock gaskets unless you drive it like a pansy for 10k miles, then do a hot retorque. (not advising it, as we don't install/run ARP's for head studs..not sure what the protocol is for those fasteners)
The fresh gaskets just have zero mechanical bond with the block/head...no heating/cooling cycles to get adhesion...
just my opinion.
just my opinion.
whs^^^Good to know. So it might be best to put some stock injectors in for the first 10K. Pull injectors and do a retorque, and install good injectors?
Is there a better gasket option?
yeah right
thanks for the heads up sir! i am not worried about warranty issues as there wasnt a warranty to begin with, so no biggy there... are there any better alternatives? other then a 10k cure cycle? this truck is no longer a dd so it would be hard to rack up 10k miles.. 36 to 38 psi of boost is all this setup runs so when I pull it apart, put new gaslets in, ill gate it less then 35 psi with hopes of it holding.
whs^^^
prolly not. gotta be a way around it.Be cheap to have stock nozzles put on and retune it. Or have it tuned to 300hp as is and drive it until its good to go.
better gaskets, studs with more clamping strength, fire rings, or all the above. sounds like limiting boost is best though.What are you talking about? A way around decreasing the stress you subject your virgin headgaskets to?
I think that's what he is getting at herebetter gaskets, studs with more clamping strength, fire rings, or all the above. sounds like limiting boost is best though.
Do not see a reason to swap injectors just have the tuner make a stock tune and confirm with boost gauge keeping it in the teens to low 20s.
