LETS SEE THOSE EXCURSIONS!!!!
smcox1
Holy s***!!! That looks so good!!! It just needs some Harley heads.
smcox1
20x12's would've looked so good you could of made them fit :biggun:
lx_2nv
Charlotte Hall, MD
dammit....i am thinking the same. hmmm, wonder how much i could offload these for?
When you installed your ranchhand, did you remove the t bar that prevents ride ups in case of an accident?
It was on the truck when I bought it...if it is like everything else whatever was easiest and sloppiest was the chosen method :/
weekendwarriorfsw32
Central California
Ill throw mine up here.
Recently did an 05 axle swap under it with a 4-link and riding on King Coilovers, BMF's wrapped in some Nitto 420's and of course a set of One Up Off-Road traction bars.
smcox1
It would be drop dead gorgeous with 20x12's
stonepusher
San Antonio
Been thinking about doing 05 axles and suspension on my ex, was it fairly easy to do? I converted my white truck from 2wd to 4wd so I was kinda hoping it would be just as easy to do the 05+ suspension conversion on the excursion.
Bustedknuckles
Here's mine I just bought off a customer. 03 limited with 150,000 Lost lost low pressure oil and had copper in the oil so its getting a 31,000 mile engine w head studs and a egr delete.
fordman2121
huntington, in
Ive posted mine before but we just got done doing the coil swap as well. It rides and drives so much better! I was even able to tuck in the 325s on just a level kit on the front and a touch of trimming in the inner fenders. Just have to get it aligned now. O and it stops better also with the bigger brakes and it can be turned at idle now with foot on the brake. Never able to do that before even with a new gearbox and pump.
stonepusher
San Antonio
Nice, was everything bolt on for the swap?
average
Central PA
Waiting on some u-bolts to get the rear suspension sorted out and traction bars installed. De-chroming will continue after that, doing all white ptm and 08 mirrors.
The Butcher
My '05. Full Traction 4-link with King Coilovers. Rides SOOOO much better than the 6" Skyjacker leaf set up I had before. Took off my 175 injectors to go back to factory since I kept having to replace the 175s every 5-6K miles. Kept my IDP tunes, and it still runs like a scalded dog.
