TrailerHauler
I think it'd time for a pcs controlled bts
I was thinking the same. LOL
350/400's and now 250/200's
Just want to point out that I was always taught you always want to have a more capacity as than you can use. You do not want to bottom out the plunger ie empty the injector. More fuel capacity I do not see as a bad thing its whats called for that matters so too little is an issue but to much...not sure how that hurts anything.
As I eventually planned to go up to 400% when I got the build done and compounds I saw no reason not to get the full fuel capacity I could get right from the start even though 200% will never come close to using it.
A gtx4294r cannot clean up 300/200. That is why Spongebob went to a gtx4202r. On gearhead tunes it can but full power wasn't there
