valvebody swap out and upgrade.
n54power
The truck has a built trans but the only complaint was the valve body used,Trans go unit with billet TC,shaft and pan.
I'd like it to be a little snappier and work better with my php tunes.
Leaning towards the JW but I'm not finding alot of detailed descriptions of before after results.
I've read that bts builds you a vb based on what you want out of it.
I want to drain the fluid,install a new vb and bypass delete and filter.
n54power
Sorry,about half my message dropped off.
Who offers a more aggressive engagement?
FrankTheTank
Cecil County, MD
I had a BTS valve body on my trans and loved it. I hear JW valve body's are very comparable in the way it shifts. BUT.... BTS has a reverse delay while JW does not
n54power
I wanted to pull it and gave it to tall freshened up but I have a e4od I need to pull out of a 1996 bronco so I can sell it.
n54power
What fluid do I use now t h at merc V isn't around.
I'm do for a fluid change.
gnxtc2
Bergen County, NJ USA
When you restrict the reverse passage in the valve body, you get that reverse delay. The restriction is done to reduce the jerkyness when put into reverse but you can sit there and finish your coffee waiting for reverse.
Billy T.
gnxtc2@aol.com
FrankTheTank
Cecil County, MD
Obs trucks aren't smart enough to achieve that effectively. Yes it does do it, but should be done at the trans
Billy..... good to know, but that reverse delay seems like an eternity sometimes
